Kpro PRB open loop no A/F in display datalog
Posted: Wed May 05, 2021 7:51 am
by goppe
Hi, I have a rsx 02 with prb ecu. I wanted to make a datalog and adjust fuel values but when I have the wideband settings on open loop it doesn't show anything.
Anyone knows how to see the A/F ratio?
Re: Kpro PRB open loop no A/F in display datalog
Posted: Wed May 05, 2021 10:01 am
by CalibratEd
Post the calibration file and datalog. Are you using the OEM wideband or do you have an external wideband? The settings might be wrong.
-Ed
Posted: Thu May 06, 2021 12:23 am
by goppe
I have a denso wideband in stock wiring.
I am on my Phone atm dont have access to the calibration and datalog from here.
I have checked for any setting but could only find for external wideband.
Posted: Thu May 06, 2021 7:55 am
by CalibratEd
Post the calibration when you can. I might know the issue but I need to confirm with your current settings.
-Ed
Posted: Thu May 06, 2021 12:48 pm
by goppe
Hi, here is my calibration. My datalog is on my laptop and I don't have it near me because I forgot in my garage.
Posted: Thu May 06, 2021 3:28 pm
by CalibratEd
If you are using the built in wideband you need to select "Built in wideband - PRB, PND, PNF" under the Closed Loop Operation. You also need to zero out the trims so the o2 sensor does not correct while you are trying to tune.
-Ed
