h22a turbo cant go past 4500 rpm at wot
Aliecb7
Post by Aliecb7 »
at wot i cant get past 4500 rpm on about half or so i cant get past 4500 rpm i attached the data log and calibration
Re: h22a turbo cant go past 4500 rpm at wot
It appears to be related to VTEC engaging. Check your grounds, especially the thermostat housing ground.
Aliecb7
Post by Aliecb7 »
Spunkster wrote: Tue May 04, 2021 10:41 am It appears to be related to VTEC engaging. Check your grounds, especially the thermostat housing ground.
yeah man all grounds are good i have the grounds at the thermostat along with the coil on plug ground there also
in was thinking vtec related i have powered the solenoid and it sound like it is working maybe i take it off and check if its blocked up with gunk , ill try also to disable vtec to see if problem is still there
Post pictures of all the grounds in the engine bay.
BoostedLude96
Post by BoostedLude96 »
Did we ever figure this problem out. My h22a keeps cutting out at wot at 4500rpm.
Aliecb7
Post by Aliecb7 »
BoostedLude96 wrote: Sat May 15, 2021 3:53 pm Did we ever figure this problem out. My h22a keeps cutting out at wot at 4500rpm.
no not yet i did a new map and just reposted a new map file and data log
Aliecb7
Post by Aliecb7 »
It was my tune file I found a basemap file from a user on here used his file and set it up for what I'm running and car pulls strong now
print3dnc
Post by print3dnc »
What was the cause though?
