B18c base map
Tonee009
B18c base map
Post by Tonee009 »
Hi guys, new to Hondata....
I just finish installed Skun2 IM, Skune stage 2 tuner cams, type R header, AEM cold intake, RDX injectors, 70mm throttle body.
Can someone help with a base map till I get it tune in June. Thanks....
CalibratEd
Re: B18c base map
Post by CalibratEd »
Post the calibration file and a datalog so we can help dial it in.
-Ed
Instagram: calibrated.tuning
SycRedDevil
Re: B18c base map
Post by SycRedDevil »
@ Calibrated - I will be doing the same here as well. New to the thread but dialing in on this one, so I don't start a new thread :-)
CalibratEd
Re: B18c base map
SycRedDevil wrote: Mon Apr 26, 2021 7:48 am @ Calibrated - I will be doing the same here as well. New to the thread but dialing in on this one, so I don't start a new thread :-)
It is best to start you own thread with information about your build. Once the tuning process starts it may get confusing.
-Ed
SycRedDevil
Re: B18c base map
Got ya. I just found my map for my specific build, and waiting on new 550 injectors.
CalibratEd
Re: B18c base map
SycRedDevil wrote: Sat May 01, 2021 10:04 am Got ya. I just found my map for my specific build, and waiting on new 550 injectors.
Sounds good.
-Ed
