Traction Control for newbs
Posted: Tue Mar 30, 2021 9:01 pm
by cholter
It’s finally spring in Minnesota, we finally can get traction, no snow!!!
I have an FK8 2019 with base tune for 91 octane, improved throttle response and traction control.
I am new to tuning, and TC...When the traction control kicks on in either of the 3 modes, it feels like someone it hitting the brakes then the turbo goes splish! We accelerate again and when the TC kicks on the magical brakes get applied.
It’s super noticeable, and doesn’t seem right.
Do I turn the Honda TC completely off by holding down the VSS button for 10 seconds?
Leave it on?
Any help would be appreciated!
Re: Traction Control for newbs
Posted: Wed Mar 31, 2021 6:57 am
by cholter
Could this only be happening when the engine is "cold"
Does the car have a closed loop, until it gets to optimal temperature?
I had a 06 civic si before this and the vtec would not kick in until the engine was warmer....
Posted: Wed Mar 31, 2021 12:13 pm
Have you tried allowing more slip with the traction control settings?
Posted: Wed Mar 31, 2021 12:27 pm
by cholter
I am not that confident in my "tuning" abilities. I got the Hondata just in case I do mods later. It's nice to clear codes etc.... I also heard the TC is super awesome. So I would need to do a ton of research to figure it out.
Thank you for replying Spunkster!
Sounds like you are having the factory VSA kick in. Post your calibration and a datalog.
Posted: Wed Mar 31, 2021 12:39 pm
by cholter
Should I do a datalog while accelerating? thats probably a dumb question... since TC doesnt turn on standing still.....lol...
Posted: Wed Mar 31, 2021 3:26 pm
by cholter
Hondata wrote: Wed Mar 31, 2021 12:27 pm
322.fpcal
datalog3-31 log01.fpdl
datalog3-31- log00.fpdl
Posted: Wed Mar 31, 2021 3:28 pm
by cholter
In the first data log file 00, the severe "Braking" happened. I was in R+ mode for file 00, and sport mode for file 01.
If there is a specific way to do a datalog, besides running up from 2nd gear to 3rd in each mode, please let me know.
Posted: Thu Apr 01, 2021 8:41 am
It is the factory VSA closing the throttle. This is because the amount of power in 1st & 2nd gears is a lot more that what the tires can cope with (and probably 3rd too). The solution is to reduce the torque in 1st, 2nd & 2rd for sport and R modes.
Posted: Thu Apr 01, 2021 8:48 am
by cholter
Hondata wrote: Thu Apr 01, 2021 8:41 am
I am glad that what i attached was helpful. Now i need to figure out how reduce torque in those gears, and by how much.
Posted: Thu Apr 01, 2021 11:04 am
by cholter
Here are the boxes checked.
Posted: Thu Apr 01, 2021 12:05 pm
In the throttle section you can reduce the torque requests for all gears and modes.
Posted: Thu Apr 01, 2021 12:32 pm
by cholter
Spunkster wrote: Thu Apr 01, 2021 12:05 pm
I have not ventured out of the check boxed calibration area yet. I am certainly not a tuner.
more research is needed....
Posted: Sun Jun 06, 2021 7:36 am
by Sayanythng
Let me know when you find the sweet spot for your throttle section I have the same issue
Posted: Sun Jun 06, 2021 8:44 am
by cholter
Turning the factory VSA off by pressing the button for 3 secs is good. In R+ mode hold it for over 10 seconds. With VSA completely off R+ mode is better.
Reducing torque in 1st & 2nd helps as well.
