I also have a ICM Fuel Sender Unit: https://ironcanyonmotorsports.com/icm-fuel-sender/
From research here are my ohms values for Empty: 4080 and Full: 252 on an 1994 Acura Integra GS-R.
The issue is I'm getting a reading on my cluster showing 100% without the fuel plugged in and I'm not quite sure if I set the Analog0 Channel correctly.
Do I put Custom for conversion, Percent for type/unit and do I need to put anything for custom input?
