Hondata Flashpro wont upload calibrations independantly
DylanD
Post by DylanD »
I recently bought a used hondata flashpro for my 08 civic si and it is able to flash to the ecu but only when my laptop is plugged into the flashpro and you hit upload from the hondata application, I am using the latest software version being 3.7.3.0 and when I upload to the ecu with only the flashpro to switch between maps the check engine light flashes and the program light on the hondata flashes but nothing happens after that and when I plug the flashpro I am greeted with "Faliure Code 0x02 Step 3 Address 0x000000". I am wondering if anyone has had a similar issue and if there is a solution or if my flashpro is defective.
Re: Hondata Flashpro wont upload calibrations independantly
