Knock Around 1k RPM
Posted: Thu Mar 11, 2021 1:41 pm
Good morning/Good afternoon,
My s2000 been experiencing some possible ghost knocks, it happen around 1k rpm, with very low throttle input.
Knocks are registered almost every time car is moving from a dead stop, then almost no knock will ever been registered once car is moving.
Car has the following parts, Spoon snorkel with a cooling plate, Spoon engine/diff mounts, HFC, HKS SSM. Valves were adjusted few month ago, same time plugs were changed.
I been pulling timing on the ignition on the area, so far, reduced by 3 degree, helped a bit but did not resolve. increased knock sensitivity table a bit as well around the area.
Could this be a fuel issue? or ghost knock of some sort? How does AF ratio looks around the knock to you guys?
Attached a log, I tried to mimic the stop and go traffic at end of the log.
I am getting a professional tune soon, i figure it is a good to figure this knock out first if possible.
Thank you for your help.
