07 si hybrid intake only base map
daniel07si
Post by daniel07si »
Like the title says need help with base map for hybrid intake on 07 si. Thanks in advance
CalibratEd
Re: 07 si hybrid intake only base map
Post by CalibratEd »
I can help you out. Can you provide datalogs with wideband input?
-Ed
Instagram: calibrated.tuning
daniel07si
sorry for the delay car was down with busted mounts
CalibratEd
daniel07si wrote: Sat Apr 03, 2021 9:16 am sorry for the delay car was down with busted mounts
Post the tune you are currently running as well.
- Ed
daniel07si
Ehmit.SD.Rev01.fpcal
this is the tune im currently running
CalibratEd
daniel07si wrote: Sat Apr 03, 2021 4:56 pm Ehmit.SD.Rev01.fpcalthis is the tune im currently running
The fuel seemed a bit spotty. I cleaned it up so we have a baseline. Datalog the car during normal driving and post the datalog.
-Ed
daniel07si
CalibratEd wrote: Tue Apr 06, 2021 9:15 am
-Ed
thanks for the base tune here's the datalog
EFICU
Post by EFICU »
daniel07si wrote: Mon Apr 12, 2021 7:14 pm
It's running on the rich side, so take it fairly easy until Ed can get it cleaned up for you. Nothing to worry about per say, just saying to give him a chance to clean it up a bit before you get too wild with it.
daniel07si
EFICU wrote: Mon Apr 12, 2021 11:36 pm
Will do, thanks
CalibratEd
Yes, It was on the rich side. I cleaned the fuel up a bit. Load the new tune file and datalog the car during normal driving and post the datalog.
-Ed
daniel07si
CalibratEd wrote: Tue Apr 13, 2021 8:10 am Yes, It was on the rich side. I cleaned the fuel up a bit. Load the new tune file and datalog the car during normal driving and post the datalog.
-Ed
CalibratEd
AFRs are getting better load the new file and datalog the car normal driving.
-Ed
daniel07si
CalibratEd wrote: Wed Apr 14, 2021 7:48 pm AFRs are getting better load the new file and datalog the car normal driving.
-Ed
CalibratEd
Part throttle looks. Data log the car normal driving with 1 WOT pull from 3000 to 8500 RPM.
-Ed
