hondata kpro 05/06 rsx
gearhead411
Post by gearhead411 »
hello, i need help I've recently purchased my hondata ecu, everything works as it should i just cannot do anything to the ecu when trying to install a calibration... i cant register with Hondata. I can see that there is currently nothing on the ecu, and my options are grayed out. I have the jumper harness, it says my usb drivers are intalled correctly, ignition says off even when its on.
Im trying to install this on my 06 Acura rsx, it currently wont start due to the key fob immobilizer. Which is the reason why im trying to install this new ecu. Please any help would be apprieciated.
gearhead411
Kpro V2 can't upload calibrations
Kpro V2 ecu everything works as it should i just cannot do anything to the ecu when trying to install a calibration.. I can see that there is currently nothing on the ecu, and my options are grayed out. I have the jumper harness it came with, and when i plug it in to the car it blinks green. But it gets hot pretty fast. Kmananger is 4.4.4, computer says my usb drivers are intalled correctly I di d that manually, ignition says off even when its on.
Re: hondata kpro 05/06 rsx
gearhead411
Spunkster wrote: Mon Feb 22, 2021 10:05 am What is the serial number that is on the K-Pro board inside the ECU?
I'm not sure which one it is. "3809", or the one above it "eb94v0" .
There is no record of this ECU being modified for use with an 05-06 RSX. Are you using an adapter harness?
gearhead411
Yes. I have the adapter harness for 05-06 rsx .
I have tried it with and without the harness, I get the same result, kmanager picks up the ecu , but I can't upload or download anything..
What is the ECU serial number?
gearhead411
The ecu serial number is 2054-100928
Is 3809 the number that is on the sticker that is on the K-Pro board inside the ECU?
gearhead411
That number on the sticker is 05008005 .
Post a picture of the adapter harness you are using, and how it is plugged in.
gearhead411
Spunkster wrote: Tue Feb 23, 2021 4:01 pm Post a picture of the adapter harness you are using, and how it is plugged in.
here's the harness and ecu.. Image
Will the engine start with the original ECU?
gearhead411
No it will not start with the original ecu because of the immobilizer. I had put a new battery in the car and that caused the key to no longer work for some reason.
Changing the battery will have no effect on the immobilizer. IT sounds like you have some other problem. Once it starts and runs with the original ECU, the K-Pro should work. Check all fuses and grounds.
