Diode for PLX wideband o2
Furble
Post by Furble »
One of the tech articles reads: “Check the voltage value with a multimeter at the output of the wideband and see how it compares to the O2 voltage above. If there is a difference, install a diode with the diode cathode pointing to the FJO and the anode pointing to the the O2 plug (green sensor ground wire) The diode is type 1N4001, Radio Shack part # 276-1101. This prevents what is called a ground loop.”
Question: Is the same diode valid for the PLX wideband?
Furble
Re: Diode for PLX wideband o2
Post by Furble »
Since it will probably be asked, the plx IS grounded direct to the thermostat housing and the voltage offset is very small. Curious if I could get it down to zero and perhaps this diode trick would accomplish that.
define very small
Furble
Post by Furble »
-0.04 volts
Don't worry about it.
Furble
Post by Furble »
Roger that.
