k series questions for k pro.
JiNx0013
Post by JiNx0013 »
looking to see if my ecu is from a auto rsx? 37820-PND-A55. my swap is in a 99 ek, If it is an auto ecu is there a reason why my cluster is now reading 7mph less then what its actually going? never did this before the swap was b series before.
also i wanted to know if i could do the following to it?
switch connector A pin 18 to the digital side of the ecu circuit board to get my vss to work properly. currently reads 3mph all the time. cluster reads 7mph less then actual speed as well.
https://www.hondata.com/tech-alternativ ... ngine-swap
switch the pins on B7 to B22 to get my reverse lockout to work
viewtopic.php?f=12&hilit=Pnd&t=21674&si ... 63a4f26254
sorry for all the questions and thanks for your time
JiNx0013
Re: k series questions for k pro.
Post by JiNx0013 »
Its a V4 k pro
The automatic ECU has no control over the cluster as there is no VSS output from the ECU. The cluster is directly controlled by the signal from the vss.
JiNx0013
Post by JiNx0013 »
Spunkster wrote: Mon Feb 15, 2021 10:35 am The automatic ECU has no control over the cluster as there is no VSS output from the ECU. The cluster is directly controlled by the signal from the vss.
thanks for the reply so since in getting the p0500 code and its an automatic ecu. should i switch connector A pin 18 to the digital side of the ecu circuit board to get my vss to work properly?
Only the ECU will see the signal if input to the K-Pro board. Ay reading you get on the cluster cannot be changed unless you use an aftermarket speed converter.
JiNx0013
Post by JiNx0013 »
awesome so i need a aftermarket converter thanks. now to get my k pro to read my speed sensor, i need to put the pin on the k-pro board right?
That is the only way an automatic ECU can see the VSS signal.
JiNx0013
Post by JiNx0013 »
thanks for all the info its working now!!
