AC Switch
Posted: Fri Feb 05, 2021 2:54 pm
I'm currently doing a k20a2 swap in to my mr2 spyder, The instructions i have say that i use the vtech pressure switch (Honda ECU (B9)) reused to be the ac switch.
I've been through the provided K-pro setup 4-5 times, everything looks right and the ac still doesn't work/
If all of the settings are correct and as i understand it it's ground to activate, If i ground pin B9 should the revs of the engine increase ?
