Xdi pump fuel pressure.
Posted: Wed Feb 03, 2021 1:49 am
I see in the fuel pressure that the xdi pump mod settings ramps up pressure as rpm increases. I am aware that lower pressure means more volume to a point.
I do understand that lower pressure can increase volume.
Is there any other reason that the pressure is ramped up in this fashion?
Is there more load on the camshaft risking cam shaft damage by increasing the pressure to say 190mpa from 4000 to redline?
Any insight to the reasoning would be great thank you.
