Help need ECU gone in recovery mode
Civic 2016+ 1.5 Turbo
salik990
Post by salik990 »
Hello Everyone,
I have been using flashpro since 2018, few days back i was flashing to another new map but suddenly this laptop battery died in the middle of flashing. Now my car is not starting nor i can reflash back to stock, everything is connecting on flashpro but ECU showing yello exclamation which mean recovery mode. I tried reseting the car by removing negative battery terminal and restart the laptop but nothing help.
Re: Help need ECU gone in recovery mode
If the ECU is in recovery mode then do not try to start the engine.
Switch off the ignition, unplug the FlashPro from the vehicle and laptop, make sure FlashProManager is up to date, then plug everything back in and then try to return to stock.
If return to stock does not work then we need to know exactly where it goes wrong.
salik990
Post by salik990 »
Thanks its working now, flashpro needed to be updated as flashpro manager.
Thanks for the update.
