error code, wide band close loop problem
brembomaster
Post by brembomaster »
hello everybody,
I got the error code 13( BARO) and code 16 (injector), Does these codes effect to the target air fuel ratio in close loop? Because of my set up target AFR is 13. but the AFR quite lean is 15 when these code light on. after that, I clear both codes and set to disable (BARO) and (injector) error. idle AFR change to 13 and keep stable. But the AFR is not stable when I keep in other rpm , the AFR will non-stop move up and down from 12.X to 14.X
what the means is Injector error? Do I need to replace injector? what wrong if I disabled the error? I cant see what issue with all injectors.
And i find a problem that my engine can not hold in 2000 rpm, when I want keep in 2000 rpm, will drop down to 1000 rpm go up 2k rpm and drop again. but it can hold in 3000, 4000, 5000.
anybody can help?
Re: error code, wide band close loop problem
What is the part number of the ECU you are using this in?
brembomaster
Spunkster wrote: Thu Jan 07, 2021 11:37 am What is the part number of the ECU you are using this in?
I am not sure the part no. , but I know it is hondata s300 v1
You will need to look at the ECU part number that is on the ECU.
