TPS Reading 100%
Posted: Sun Jan 03, 2021 3:31 pm
by Johnr051
When looking over the data log it shows my TPS running 100% when closed?? im assuming i may have switched the map and tps plugs by accident, is there a possibility my map sensor fried out????
Re: TPS Reading 100%
Posted: Mon Jan 04, 2021 7:00 pm
You will have to verify they are plugged in correctly and then make sure you calibrate the TPS properly as well.
Posted: Wed Jan 06, 2021 5:17 am
by Johnr051
I fixed the wiring now the tps is calibrated but the car won’t start, it just back fires on the intake. I’m attaching a picture of the sensors and data log also my base map just incase
Posted: Wed Jan 06, 2021 9:58 am
Post a datalog of it trying to start
Posted: Wed Jan 06, 2021 1:21 pm
by Johnr051
i sent it
Posted: Wed Jan 06, 2021 1:54 pm
The TPS does not appear to be calibrated correctly as it is at 9% when trying to start and should be at zero.
Posted: Wed Jan 06, 2021 5:57 pm
The MAP is reading 22 kPA cranking - it should be around 100 kPa. So either the MAP is bad or the calibration setting is wrong.
Posted: Thu Jan 07, 2021 3:00 pm
by Johnr051
I calibrated the tps to 0.5 closed, car fires up better but it doesn't completely starts. I'm sending the datalog of it trying to start with the calibrated tps
Posted: Thu Jan 07, 2021 3:26 pm
by Johnr051
Hondata wrote: Wed Jan 06, 2021 5:57 pm The MAP is reading 22 kPA cranking - it should be around 100 kPa. So either the MAP is bad or the calibration setting is wrong.
how can i calibrate it on the kmanager also how can i test if its gone bad its a new 4bar map
Posted: Thu Jan 07, 2021 4:44 pm
The MAP stays at 22 kPA no matter what else happens so it is either the wiring or MAP sensor. If you switched the TPS and MAP then the MAP probably is toast. Another silent curse that Honda used different plugs for everything in the vehicle apart from the two connectors next to each other.
Posted: Thu Jan 07, 2021 4:57 pm
Also note that if a MAP sensor is wired incorrectly even for a split second it will damage the MAP sensor and it will have to be replaced.
Details on calibrating the TPS can be found at: http://www.hondata.com/help/kmanager/th ... ghtsub=tps
Posted: Thu Jan 07, 2021 5:21 pm
by Johnr051
Hondata wrote: Thu Jan 07, 2021 4:44 pm The MAP stays at 22 kPA no matter what else happens so it is either the wiring or MAP sensor. If you switched the TPS and MAP then the MAP probably is toast. Another silent curse that Honda used different plugs for everything in the vehicle apart from the two connectors next to each other.
I understand but before my car was starting with the same wire set up and 4 bar, I replaced the trans and fixed the tps and it doesn’t want to start completely also I tried my stock map sensor and calibrated it to match it and it still didn’t start up completely
