rpm limit
ian
rpm limit
Post by ian »
just completed a engine swap, b16a into a 89 crx. problem is ,the engine will not rev higher than 7200 rpm. ecu is a pr3, distributor is a 91, engine is a 94 jdm. any suggestion anyone.
pills_PMD
Post by pills_PMD »
you're using a pre-OBD computer on an OBD1 engine.
that may have something to do with it... do you have hondata?
QUICKSILVER RACING
Post by QUICKSILVER RACING »
No problem I see there. If you look at jdm 91 civic instrument clusters. redline is at 7000 or 7500
HONDATA official and sole Distributor in the Philippines.
http://quicksilver.4t.com
+639178954747
pills_PMD
Post by pills_PMD »
i know a few people with first gen b16 engines in their hatch using a pr3 and there rev limiter kicks in after 8000 though...
QUICKSILVER RACING
Te be sure o theexact Rev limit, use a frequency counter in the timing light to be precise.
+639178954747
Rev limits
7000 rpm is usually because the ECU thinks the engine is cold. Check the ECU's temperature sensor, and that the termostat is working etc.
