Crankshaft sensor
Johnr051
Crankshaft sensor
Post by Johnr051 »
I just swapped my eg from k20a3 to k24 turbo, I started the car but 2 problems occurred
1. It won’t stay on unless I continue giving it gas
2. I’m getting a P0035 code for crankshaft sensor and it’s a fresh motor from jdm depot, I’m using a k20 harness do I have to swap some wires or sensor?
Re: Crankshaft sensor
Try swapping the crank sensor from the K20 and see if that resolves the issue.
Johnr051
Post by Johnr051 »
Swapped it code is gone now thanks much appreciated
