Error code 13 BARO
R1gge
Error code 13 BARO
Post by R1gge »
Hi, I just got a 92 EG with a B16A2. I get a fault code for 13 BARO. It has an EU ECU.
The whole internet says to check the box for disable barometic pressure sensor (since EU ECU´s don´t have that circuit), and all the answers says it solves their problem.
On mine i can click the box, upload and everything is fine, but as soon as i press the red button to clear error codes the thing turns off and wont start anymore.
I tried all other base maps that i think could work but it wont start unless i use the one who was in the car when i got it.
First testdrive it didn´t have the check engine light on but the first thing i did was lower the idle rpm, as soon as i hit upload the car died and we had to load the stock map again and it worked, but with fault codes for injector and baro.
We turned off ELD and injection error and that worked. Now its just baro left.
This car hasnt been touched in like 10 years, maybe all the software updates have something to do with it?
Re: Error code 13 BARO
What is the serial umber that is on the s300 board inside the ECU?
lester1968
Post by lester1968 »
Hi. I´ve same error plus 9 and 16. Is there somebody who could fix it?
What is the ECU part number?
