V4 datalog freezes
cabah
V4 datalog freezes
Post by cabah »
Any one here had similar issues? where the ecu plugs in and laptop says online and normal, and when you try to read sensors to recal the tps and others it freezes to a certain values, and everything i reboot the k manager and do it again, it datalog freezes to the same values again. engine MIL is on and i cant check it either.
HELp
i got some video i will load up
cabah
Re: V4 datalog freezes
Post by cabah »
It always stuck on these
Values whenever datalog, car starts, mil on, and loud and unload maps(i think anyway)
cabah
Post by cabah »
Tried a V1 on the same car, works fine. 🤷‍♂️
Who installed the K-Pro into this ECU?
cabah
Post by cabah »
This unit here we got it from Speedscience, New Zealand. I been doin some researching, is the PRA ecu have different ecu pin out thats causing this? any input would be great!!
thank you
What vehicle is this being used on?
This was sold as an install kit. You may want to have Speedscience take a look at the ECU as well.
cabah
Post by cabah »
Hi, this is goin on an S2000 with a K24 swap, 2NRS PNP harness etc. Got it running on the V1 currently to get other small things done. I have contacted Speedscience and it looks like might the ecu it self is the issue. The faulty V4 can upload and start car running, but cant recal or data log anything.
Thank you
regards
