FlashProManager 3.6.6.0
Posted: Fri Oct 30, 2020 8:14 pm
V3.6.6 (30 Oct 2020)
To recover the FlashPro security password you will no longer be sent the existing password. Rather you will be sent a reset code to either your email or phone that allows you to reset your password. This way the password does not leave the FlashPro. Make sure to check that your email and phone number are correct. International users should use the international calling prefix + and their country code.
The non-Si 10th gen Civic have a new modification which disables the artificial knock control increase above 5500 rpm. There is no downside or risk to enabling this modification (disabling the artificial increase) so we recommend everyone enables this modification. Some 2016 vehicles do not have this artificial knock control behavior so don't panic if your calibration does not have the modification shown - it already is disabled.
- FlashPro password reset now sends a reset code to the owner email or phone
- [2016+ Turbo Civic] Added boost by ethanol limit
- [2016+ Turbo Civic] Added artificial knock disable for WOT as a modification
