Problems with flash pro
Posted: Sun Oct 25, 2020 2:19 am
Hello
I have 3 problems and if i would like tell this to someone if possible to fix or you cant do anything.
First with cruise control. I have +6psi and +3psi but C.C dont work correctly especially in the downhill. I dont have constant speed but all the time acceleration and brake. All the time is this .not constant speed like normal without saddenly acceleration and suddenly brakes. Second If i touch gas pedal when i have Cruise control and remove my foot i see the speed will be increased and i will pass the limit . Only if i touch brake pedal stop the acceleration and my speed goes to the cruise control number.
And the last one is with econ mode. When i have econ mode i have the same acceleration of my car like i didnt have econ mode. I cant find difference and ofcourse the pressure with 3 psi is the same with econ mode and without econ mode.finally, When i have econ mode and flashed program 3 psi i must see stock pressures or increased pressures( +3psi )?
Mycar is 1.5 turbo civic international. Ecu part number is 37820-5AW-G32
