Need help on Aem wideband install on b18c1gsr
Ciroracing25
Post by Ciroracing25 »
I am installing my aem wideband to my hondata s300. Does anyone have installation instructions for an acura with a b18c1. I do not want to mess up my new ecu
DaX
Re: Need help on Aem wideband install on b18c1gsr
Post by DaX »
Have you looked over the help topics? They are pretty informative. Open SManager, go to Parameters and click on the "Closed Loop" tab. In the top right corner of the window, click "Closed Loop Help" (blue text). You should also look at the help file that is on the "Closed Loop Advanced" tab as well. These, combined with the instructions that came with the wideband, should be all you need.
Gixelz
Post by Gixelz »
White wire on AEM to D10, brown and black to ground on ECU, red to power on ECU.
Set S300 to use D10 under Closed Loop Advanced.
