Broken ecu. Can’t reset to stock to unlock.
Posted: Fri Oct 23, 2020 3:13 pm
by deadpoolfg4
Was in a wreck and the ecu is in no shape to be reflashed to stock. So I can not unlock the flash pro. I tried calling support but due to covid it’s closed. I would love to use my flash pro on my new car. Thanks!
Re: Broken ecu. Can’t reset to stock to unlock.
Posted: Fri Oct 23, 2020 3:40 pm
What is the serial number that is on the FlashPro?
Do you have the ECU that it is locked to?
Posted: Fri Oct 23, 2020 6:42 pm
by deadpoolfg4
I can get both as soon as I’m home. Am at the dealership purchasing anew type r :)
Posted: Fri Oct 23, 2020 6:43 pm
by deadpoolfg4
I can get the physical ecu but cannot use it in the car as I believe some of the wires are cut from the accident
Posted: Sat Oct 24, 2020 12:23 pm
by deadpoolfg4
Spunkster wrote: Fri Oct 23, 2020 3:40 pm What is the serial number that is on the FlashPro?
Flash pro serial number : FP-2012si-113917
Posted: Mon Oct 26, 2020 3:34 pm
Put the ECU into another vehicle and you will be able to return it to stock and properly unlock it.
