p2185
ckj134
p2185
Post by ckj134 »
Hello, I got my ECU replaced and programmed to my immobilizer, I think I got the vehicle tune not sure it does the tune under 15 seconds, the online videos I am seeing all say it should take 5 mins but those are for civics, anyway after I got the tune done I keep getting this code P2185 ECT SENSOR CIRCUIT HIGH VOLTAGE.
Re: p2185
If it only takes 15 seconds to upload, then it is not uploading to the ECU. What does it show in the lower left corner of the software when you are trying to upload?
ckj134
Re: p2185
Post by ckj134 »
in the bottom everything is green expect the the logo that says that the ecu is locked or that the flash pro is locked.
Re: p2185
ckj134
Re: p2185
Post by ckj134 »
right now the code im getting is p2185 thats my only issue for now, but I will try that.
ckj134
Re: p2185
Post by ckj134 »
So for whatever reason the flash pro was putting the tune into the obd2 dongle not my vehicle, I hooked up the flash pro held down the program button the dongle started flashing different ways saw some action on my dash check engine came off.
I adjusted these settings not sure if I did thus correctly
Re: p2185
Was the FlashPro plugged into the vehicle with the ignition on when you were uploading to it?
ckj134
Re: p2185
Post by ckj134 »
Yes I had the vehicle in the on position, held the program button it was solid then it started to flash a few mins and some lights in the dash came on and off, last thing it did was the check engine when on and off, it never did this while I had the computer plugged in.
