Cause of coil pack to get hot?
Posted: Sat Oct 17, 2020 12:44 pm
by Hndelsol26
Car and engine is:
94 civic SI
B18c
B18b1 crank
Wiseco pistons 8.6:1
Skunk 2 rods
Stock head
ARP head studs
Edelbrock intake manifold
70mm blox throttle body
4bar ktune map sensor
Rc 1000cc injectors
Hondata cpr kit
Denso 673-2301 coil packs
Hondata S300 v3
eBay gt3582 turbo
Rywire engine harness
Ngk 9 spark plugs
So I recently have a misfire and I was trying to diagnose the issue and before the misfire, the car had a bad injector and I replaced them.
At first it was hard to start. After I got it to start, it seemed to idle fine and then about a minute later, it started to sound like it was down a cylinder and sounds like a Subaru. Then about 5 minutes of idling, I just so happen to touch the coil pack to see if they were in tight and only cylinder 4 coil pack was hot. The rest of the coils were not hot.
So I’m not trying to get answers for my misfire, just wondering what would cause a coil pack to be hot? Or is this normal?
Re: Cause of coil pack to get hot?
Posted: Mon Oct 19, 2020 9:11 am
Based on your other post you have had a wiring problem and it has damaged the CPR box.
Send and email to support <at> hondata.com with the following and I will issue an RMA and give you further
instructions:
Name:
Address:
Phone:
Email:
Serial#:
Description of problem:
include a link to this thread.
Posted: Fri Nov 04, 2022 12:44 pm
by foolish1
Did you ever figure out what the issue was yet I am having the same issue
Posted: Sun Jan 19, 2025 2:23 pm
by gotslicks
Had same issue once. My original ground on my thermo housing was super loose. The cop ground was on other bolt and I didn’t realize I loosened the other ground.
