Kpro V3 boost control issues
Posted: Sun Oct 11, 2020 8:33 am
Having an issue with the boost control on my civic. The tables for boost by gear have been setup correctly but for some reason the ecu is not sending the correct duty cycle percentages to the controller. For example 1st gear should be 10psi at 15% duty cycle but the ecu is sending 35% duty. If we change the maximum duty cycle that is what the ecu will send to the controller. its like its stuck in fixed duty when it should be on gear based duty cycle. I have posted 2 images of the boost table and the graph. On the graph it states 35% duty this happened when we set the maximum duty cycle to 35% if we had left it at 52% that's what it would have hit if that makes sense
I have attached bot the data log and the calibration any help is appreciated
