Page 1 of 2
10.7 A/F Stuck on Mobile App
Posted: Sun Oct 04, 2020 2:08 pm
by swapdef
Good Day,
I'm working through the mobile app and I'm noticing that the wideband display stays stuck on 10.7. On kmanager I do have proper display for A/F-does anyone know if there are any settings I may be missing? I browsed the forums and someone went through a similar issue-they stated to have changed a setting for "mixture adjustment". Is anyone familiar with what setting this is on Kmanager or Mobile App?
Any help will be appreciated. Thanks.
viewtopic.php?f=48&t=18435&p=82007&hili ... and#p82007
Re: 10.7 A/F Stuck on Mobile App
Posted: Mon Oct 05, 2020 9:13 am
You need to post your calibration as well as a datalog showing the issue.
Posted: Sun Nov 08, 2020 8:27 pm
by swapdef
Good Evening,
I will like to reiterate that in kmanager everything is displaying properly. Only issue i'm having is not being able to get the analog inputs displayed on the mobile app. I did hear back from someone that handles mobile app inquiries, and they informed me that it's not an app issue. I was advised to reach out to support@hondata.com for further assistance. Attached you will also find a screenshot of the conversation that was had.
Please let me know if there is anything that can be done.
Posted: Mon Nov 09, 2020 11:44 am
There is no reading in KManager either. How exactly do you have this wired?
You have it set to open loop. And do not have it set to read an aftermarket wideband on an analog input.
Posted: Mon Nov 09, 2020 6:17 pm
by swapdef
Good Evening,
Thank you for your response. When you say "There is no reading in KManager either", are you referring to the Analog 0 slot? On my end I have AF reading at that input. Attached you will see that there are readings being displayed at that input.
The wideband is wired as such: sensor wire goes to Analog 0 input, power source is connected at an external source, and ground is connected and the ground pin on the kpro analog board.
My tuner set the parameter to open loop. Does this setting conflict with the incoming signal from the wideband going into the analog input?
Posted: Tue Nov 10, 2020 10:09 am
You need to go to the Closed loop section of the parameters window and make sure you have it set to use signal from an analog input. You should then be able to see the correct reading in the KManager software.
Posted: Tue Nov 10, 2020 11:57 am
by swapdef
Thanks for the response...
Just to clarify, by changing to "external wideband input" in the "closed loop parameter", will it affect how the fuel content is being read/delivered by the ecu?
I was under the impression that wideband were only for datalogging and monitoring purpose only-Please correct me if i'm wrong.
Posted: Tue Nov 10, 2020 12:11 pm
No it can be used for closed loop input through the K-Pro board.
Posted: Tue Nov 10, 2020 12:18 pm
by swapdef
Understood. I just changed the setting to external and the mobile app still shows a stuck value of 14.7
Any other suggestions?
Posted: Tue Nov 10, 2020 12:23 pm
Does it read correctly in the Kmanager software?
Posted: Tue Nov 10, 2020 12:28 pm
by swapdef
Just so I'm on the same page as you... Where am I supposed to look at to verify if it's reading correctly?
I have been relying on the sensors table under ANALOG 0 for the input signal. I have A/F fluctuation @ AN0 which leads me to think that it's reading correctly.
Is that not where I'm supposed to be looking at?
Posted: Tue Nov 10, 2020 12:59 pm
AF in the sensor list in KManager.
Posted: Tue Nov 10, 2020 1:29 pm
by swapdef
Yes. I have been looking at the AF display as well and there is an output signal that responds accordingly to WB.
Screen shot attached shows a value of ~17 aka lean.
Please advise if any further can be looked at.
Posted: Mon Nov 16, 2020 7:33 pm
Are you using a PRA ECU?
Posted: Wed Nov 18, 2020 6:42 pm
by swapdef
Good Evening,
I am using a PND auto ecu.
