IAT Sensor getting heat soaked
Posted: Mon Sep 28, 2020 6:30 am
Good morning,
On my b20vtec setup I am running the stock GSR intake manifold which has the IAT sensor located on the top of the intake manifold. My concern is, that once the car is warmed up, the IM gets heat soaked and my IAT’s are in the 120-135* range which isnt accurate, considering the outside temp is only 80*. My logs show that there is some sort of IAT Temp correction taking place once this happens. I assume some timing is being pulled along with fuel?
Is the solution to relocate it to the intake tube?
