2020 HB Sport Built Engine Options
Civic 2016+ 1.5 Turbo
mrburgerUS
Post by mrburgerUS »
Hello,
I am in the process of building a L15B7 motor to drop into my 2020 Sport 6MT Hatchback. I surveyed the options provided by Hondata, and I currently see a few features missing that were present on my 9th gen Si flashpro. These are:
Rev Limit Adjustment (would like to set redline to 7250 RPM)
4 BAR MAP Sensor Support
Gear Ratio Modification
All 3 of these features were available for a K24Z7, is there a plan to support them on an L15B Hatch?
Thanks!
Re: 2020 HB Sport Built Engine Options
The 9th gen and 10the gen Civic are different, so comparing features is not possible.
- Rev limiter - stock rev limit only for the moment because the limitation is the high pressure fuel pump, which is rated at 3600 camshaft rpm.
- 4 bar MAP - Si only at the moment.
- Different gear ratio - no support.
