Analog input v3 new to hondata
Rboost
Post by Rboost »
I have few questions regarding the analog input on the board of s300, I’m wanting to use then rather than splicing into or pin into the ecu
My questions are I would like to use AEM wide band. boost controller solenoid and coil pack
Do I take my white wire and use one of the analog inputs instead of D10?
Re: Analog input v3 new to hondata
In order to run closed loop from a wideband you must use one of the analog ECU inputs such as D10.
Rboost
Post by Rboost »
Ok thanks
What can I use for the analog inputs then? Just ideas
They can be used only for datalogging only. This means that they can be viewed but will have no effect on how anything runs or operates.
Rboost
Post by Rboost »
Ok, I understand now thank you for clarifying
