Active Tuning Target Lambda Tables
web35
Post by web35 »
Concerning Active Tuning, there is reference to a 'target lambda' table that is different from the ECU target. Is this it?
Re: Active Tuning Target Lambda Tables
I'm not sure what you are referring to.
web35
Post by web35 »
This: Where can I view or build this table that is referenced?
The image in the first post is not used for active tuning.
web35
Post by web35 »
OK......Where is the target lambda table that supports active tuning?
It is in the Calibration window in the fuel section under the Active tuning sections.
web35
Post by web35 »
Nope. No target Lambda table in Active Tuning.
Target lambda tables were hidden. Fixed for next release. Use the WOT compensation tables in the meantime.
web35
Post by web35 »
Thank you!
