Hey guys, I need a basemap to get my new build up and running.
-2009 Civic Si
-2008 Acura TSX (K24a2) bottom block with the 09 Si (K20z3) Cylinder head and accessories.
-Using the TSX camshafts with the stock VTC Wheels
-NST Lightweight Pulleys
-K-Tuned Oil Pan
-RSX Oil Pump
-I also moved over the K20z3 oil cooler with the water pump.
-Stock TB and RBC Intake Manifold
-Stock fuel injectors and pump
-93 Octane
-K-tuned Racing Header w/ pipe and 3-inch Exhaust
-We’ll go ahead with 8000 rev limit for now, If I feel it’s not enough I’ll pump it up to 8500
-K-Tuned SRI and CAI (it's easy to swap between the 2)
My question is, since the SRI and CAI can transform so easily, do I need 2 separate maps for when I switch them? Or will a single map be able to fully utilize both setups? If it’s the former, if I could get a basemap for both setups, that would be fantastic.
2009 Civic Si K20/24 Frank Basemap
XeroTech82
Return to “FlashPro Calibrations”
Jump to
- General
- ↳ Hondata News
- ↳ Applications
- ↳ Non-Hondata
- s100/s200/s300
- ↳ s300 / SManager
- ↳ S300 Calibrations
- ↳ SManager Display Templates
- ↳ s100/s200
- ↳ Romeditor 4 Software
- ↳ HondaLogger Software
- ↳ Coil Pack Retrofit
- K-Series
- ↳ K-Pro / KManager
- ↳ K-Pro Calibrations
- ↳ KManager Display Templates
- ↳ K-Series Reflash
- FlashPro
- ↳ FlashPro Manager
- ↳ FlashPro Calibrations
- ↳ Accord 2008+ FlashPro
- ↳ Civic Si 2006-2011 Americas
- ↳ Civic Si 2012-2015 US/Canadian / 2013+ ILX
- ↳ Civic Type R 2006-2010 Japanese FD2
- ↳ Civic Type R 2007-2011 European FN2
- ↳ Civic Type R 2015+
- ↳ Civic 2016+ 1.5 Turbo Americas/Asia
- ↳ CRV 2017+
- ↳ CR-Z 2010-2012 US/Europe/Asia
- ↳ Fit 2007-2008
- ↳ RDX 2007-2012
- ↳ S2000 2006-2009 Americas/Europe/Asia
- ↳ TL 2007-2008
- ↳ TSX 2004-2014
- Traction Control
- ↳ General / Traction Control Manager Software
- ↳ Traction Control with S300
- ↳ Traction Control with KPro
- ↳ Traction Control with FlashPro
- Bluetooth Mobile Apps
- ↳ Hondata Mobile
