S manager - cant download tune
Posted: Thu Aug 06, 2020 5:45 am
by benITBdc2
Hi all, new to the forum !
I got my b18c ITB dc2 mapped a couple weeks ago by a reputable tuner in the Uk, when i was driving home the car cut out and wouldn't start, car took a good 40 dyno runs to get the map sorted on the car.
Im trying to get onto S manager to check everything is alright, newest software and drivers installed.
I can connect to the ECU and see live data, but the values for everything are all over the place
Contacted the Tuner but he is on holiday in the Alps so he cant even send me a copy of the calibration file :(
when i try to download the tune i get the following message, Does anyone know what this could be ?
The car cranks, checked spark, fpr gauge is showing fuel pressure, In car AFR is reading fine - But on S manager the AF reading just stays at 1.20
TPS is showing 0-100% movement fine, tried a new map sensor also. I cant see any error codes on the Error tab but i dont know if i have a problem with the below message.
<?xml version="1.0"?>
<data>
<date>06/08/2020</date>
<time>12:45:09</time>
<os>Windows 10 Professional (build 18362), 64-bit</os>
<language>en</language>
<country>United Kingdom</country>
<application>
<name>SManager</name>
<version>2.7.5.0</version>
<build>1435</build>
<architecture>32</architecture>
<compiledate>Thursday, February 27, 2020 10:25 AM</compiledate>
<caption>Hondata SManager 2.7.5.0 - [Display]</caption>
</application>
<additional>
<S300USBType>1</S300USBType>
<HardwareVersion>0</HardwareVersion>
<FlashMemory>0</FlashMemory>
<FirmwareVersion>0</FirmwareVersion>
<MemoryLoad>40</MemoryLoad>
<RecordingMemory>20</RecordingMemory>
</additional>
<exception>
<address>0x0098A9D0</address>
<exception>ERangeError</exception>
<message></message>
<class>TMainForm</class>
<form>MultiDisplayForm</form>
</exception>
<stacktrace>
<trace>0x0098A9D0,SManager.exe,TEncryptedBuffer.cpp(3),TEncryptedBuffer.GetByte,+4C</trace>
<trace>0x00A28B72,SManager.exe,TROM.cpp(9),TROM.GetByte,+E</trace>
<trace>0x00A1394C,SManager.exe,TROM.cpp(13),TRomTable.GetValue,+48</trace>
<trace>0x00A14197,SManager.exe,TROM.cpp(13),TRomTable.SaveToDesiredValue,+1B</trace>
<trace>0x00A3AD19,SManager.exe,TROM.cpp(1751),TROM.InitECUDefinition,+11BCD</trace>
<trace>0x009F634C,SManager.exe,MainECU.cpp(84),OnlineDownloadExecute,+538</trace>
<trace>0x009A6E8D,SManager.exe,fMain.cpp(0),TMainForm.actOnlineDownloadExecute,+1</trace>
<trace>0x00B3CC3B,SManager.exe,System(0),Classes.TBasicAction.Execute,+F</trace>
<trace>0x00BF15B6,SManager.exe,Vcl.ActnList(19),TCustomAction.Execute,+86</trace>
<trace>0x00D03717,SManager.exe,Vcl.Menus(17),TMenuItem.Click,+93</trace>
<trace>0x00D04E57,SManager.exe,Vcl.Menus(5),TMenu.DispatchCommand,+13</trace>
<trace>0x00D18AA0,SManager.exe,Vcl.Forms(5),TCustomForm.WMCommand,+38</trace>
<trace>0x009AAC56,SManager.exe,fMain.h(20),TMainForm.Dispatch,+1A6</trace>
<trace>0x00C03FE2,SManager.exe,Vcl.Controls(91),TControl.WndProc,+2BE</trace>
<trace>0x00C08A97,SManager.exe,Vcl.Controls(166),TWinControl.WndProc,+63B</trace>
<trace>0x00D1572D,SManager.exe,Vcl.Forms(209),TCustomForm.WndProc,+64D</trace>
<trace>0x00C08064,SManager.exe,Vcl.Controls(3),TWinControl.MainWndProc,+2C</trace>
<trace>0x00B3D990,SManager.exe,System(0),Classes._18202,+14</trace>
<trace>0x75303F2B,USER32.dll,(0),DispatchMessageW,+B</trace>
<trace>0x00DFA875,SManager.exe,(0),__wstartup,+12D</trace>
<trace>0x777F6357,KERNEL32.DLL,(0),BaseThreadInitThunk,+17</trace>
</stacktrace>
<actionlist>
<action>Datalog actDatalogDatalog</action>
<action>Online actOnlineDownload</action>
</actionlist>
<undolist/>
</data>
Thanks, Ben.
Re: S manager - cant download tune
Posted: Thu Aug 06, 2020 7:40 am
What is the serial number of the S300?
Posted: Thu Aug 06, 2020 8:11 am
by benITBdc2
It’s one of the older hondata units with the obd2a conversion harness built into it
S300-9941 On the hondata board
Posted: Thu Aug 06, 2020 9:12 am
The s300 has failed. You will need to upgrade to the version 3. details on upgrading can be found at: https://www.hondata.com/downloads/s300v ... e_form.pdf
