Page 1 of 2
S300 power to led lights
Posted: Tue Jul 28, 2020 12:13 pm
by 1320vickers
I have a s300 in a crx and I’ve looked to see if the d3 light stays on after the key has been switched on. It seems like it’s supposed to but mine goes off after a second I’m just trying to figure out if it’s normal or a socket issue
Re: S300 power to led lights
Posted: Tue Jul 28, 2020 1:28 pm
Ignoring the lights, is it working as it should?
Posted: Wed Jul 29, 2020 6:13 am
by 1320vickers
It will start if you force it spits and sputters
Posted: Wed Jul 29, 2020 6:14 am
by 1320vickers
I haven’t been able to connect to the laptop either No upload or data log
Posted: Wed Jul 29, 2020 9:34 am
Who installed this s300 and did the socketing of the ECU?
Posted: Wed Jul 29, 2020 12:46 pm
by 1320vickers
38715 I bought it used I’m not sure who did the socket it worked fine for awhile ever now and again I would have trouble getting it to connect
Posted: Wed Jul 29, 2020 12:57 pm
Post pictures of the bottom of the ECU showing the soldering where the s300 was installed.
Posted: Wed Jul 29, 2020 1:44 pm
by 1320vickers
Could the wiring harness have anything to do with it
Posted: Wed Jul 29, 2020 2:40 pm
It could be any number of things. I can't really see the solder joints as it is out of focus. Have the capacitors been replaced?
Posted: Wed Jul 29, 2020 2:54 pm
by 1320vickers
I’m sorry I tried to get it to focus better not that I know if I thought about ordering a kit and putting all new ones in the board has a tiny brown spot next to c14
Posted: Wed Jul 29, 2020 3:09 pm
by 1320vickers
These look better
Posted: Wed Jul 29, 2020 3:25 pm
I would start by replacing the capacitors and see if that resolves the issue, as they are more than 25 years old.
https://www.hondata.com/products/access ... acitor-kit
Posted: Wed Jul 29, 2020 3:56 pm
by 1320vickers
Done deal thank you
Posted: Thu Aug 13, 2020 1:53 pm
by 1320vickers
Ok had the ecu completely refurbished with all new capacitors and socket kit and it’s still not connecting to the laptop On the dash it says ignition off I’m thinking a wire problem but I’ve tore it apart and don’t seen anything obvious
Posted: Thu Aug 13, 2020 2:49 pm
Is J12 cut in the ECU?
