S300 power to led lights
1320vickers
Post by 1320vickers »
I have a s300 in a crx and I’ve looked to see if the d3 light stays on after the key has been switched on. It seems like it’s supposed to but mine goes off after a second I’m just trying to figure out if it’s normal or a socket issue
Re: S300 power to led lights
Ignoring the lights, is it working as it should?
1320vickers
It will start if you force it spits and sputters
1320vickers
I haven’t been able to connect to the laptop either No upload or data log
Who installed this s300 and did the socketing of the ECU?
1320vickers
38715 I bought it used I’m not sure who did the socket it worked fine for awhile ever now and again I would have trouble getting it to connect
Post pictures of the bottom of the ECU showing the soldering where the s300 was installed.
1320vickers
Could the wiring harness have anything to do with it
It could be any number of things. I can't really see the solder joints as it is out of focus. Have the capacitors been replaced?
1320vickers
I’m sorry I tried to get it to focus better not that I know if I thought about ordering a kit and putting all new ones in the board has a tiny brown spot next to c14
1320vickers
These look better
I would start by replacing the capacitors and see if that resolves the issue, as they are more than 25 years old.
https://www.hondata.com/products/access ... acitor-kit
1320vickers
Done deal thank you
1320vickers
Ok had the ecu completely refurbished with all new capacitors and socket kit and it’s still not connecting to the laptop On the dash it says ignition off I’m thinking a wire problem but I’ve tore it apart and don’t seen anything obvious
Is J12 cut in the ECU?
