A/F is different from AF/CMD
Posted: Tue Jul 28, 2020 3:21 am
by Civicx990
Hi,
Need some advise if possible, How come during WOT, my AF CMD is 11.08 but the sensor is A/F of 10.52?
Is it the stock 02 sensor not accurate as its not wideband? Or need adjust some settings? Here a screenshot. Any expert opinion would be useful. Thank you
Re: A/F is different from AF/CMD
Posted: Tue Jul 28, 2020 11:07 am
Because the ECU is in open loop, so it will not adjust the AF to match the target. And also the WOT adjustment table is not a target table.
You'll find that after a reflash it will take some driving but eventually will run in closed loop all the time apart from when the injectors are cut.
If you see a difference from target to actual the first thing to look at is the AFM calibration.
