Speed
Posted: Sun Jul 12, 2020 11:51 pm
by Bones126
Hi, does the Euro FN2 get its speed direct from the sensor or the ECU?
Is there a basic explanation for between ECU and Dash adjustment setting? I have changed the Final Drive and adjusted the dash setting only to read correct but interested to why there is also ECU adjustment
Re: Speed
Posted: Mon Jul 13, 2020 8:48 am
When you datalog the speed from the ECU does it match the dash?
Re: Speed
Posted: Wed Jul 15, 2020 12:29 am
by Bones126
Hondata wrote: Mon Jul 13, 2020 8:48 am When you datalog the speed from the ECU does it match the dash?
Hi,
It wasn't no, it was reading slower. I have since posting made the positive % increase and matched it to GPS speed. I did this using the Hondata app and taking the speed from the Sensors List and matching it to my GPS speed, is this correct way? The same as the dash.
Although the ECU % is +15 & the dash % is +9. Is this common?
thank you for your help.
Re: Speed
Posted: Wed Jul 15, 2020 9:44 am
If the ECU speed and dash speed both are the same as the actual speed then your job is done.
