stuck Map sensor reading
Posted: Wed Jul 08, 2020 6:37 pm
I've got a SOHC turbo in a 1998 civic 5 Speed. When I try to start the car it runs excessively rich to the point that the plugs get fuel fouled . The only way I can keep it running is to open the throttle almost wide open. Even under these conditions it struggles to idle and eventually fuel fouls and stalls.
When I check all the sensor values I find the MAP sensor reading never fluctuate with the engine running or KOEO.
I have checked the following:
Checked continuity from all three lines of the MAP to ECU and found no opens.
Checked for shorts to ground or B+ on the Map harness and found none.
Added additional ground wire from engine block to chassis and chassis to battery NEG. This made no difference.
Overlayed a new harness from Map sensor to ECU (pin to pin) and still no Map sensor readings changed.
Replace HONDATA 4 Bar Map with stock Honda, changed Map parameters and still unable to run properly (with original and overlay harness).
I replace the P28 ECU with a P06 from my other car and was able to get different map readings.
P28 ECU readings:
HONDATA 4 Bar Map KOEO = 44.4"/psi (with supplied base map)
Stock Honda Map KOEO = 44.4"/psi (parameters changed to stock Map)
Both sensors readings are with the original harness and the overlay harness.
P06 ECU readings:
HONDATA 4 Bar Map KOEO = -29.9"/psi (with supplied base map)
Stock Honda map KOEO = -29.9'/psi (permeators changed to stock Map)
Both sensor readings are with the original harness and the overlay harness.
If I attempt to start the car with the P06 ECU it will not start (don't know if I need to change additional parameters)
If I manipulate the Map sensor parameters on the P28 to read -15.7"/psi the engine starts and runs smoothly.
I am at a complete dead end with how to continue this diagnoses. My understanding and ability to navigate the HONDATA is limited. I suspect that the P28 ECU has a defect that is creating my problem.
Is there anything that I may be missing or do not understand that is creating this situation for me? Is there any further testing anyone can suggest I perform?
P28 ECU readings:
P06 ECU readings:
