07 Honda fit E85 tuning compatibility
2007-2008 Fit
lakia5524
Post by lakia5524 »
Hi looking for the correct and or if compatible way to use E85 fuel with the fits flashpro calibration menu with no ethanol selection like other vehicle have.
Understanding injectors,fuel lines and pump must be e85 compatible, on the flaspro tuning side using a wideband with lambda values such as the plx device that can be used for 3rd party data logging would this be enough to properly adjust fuel tables accordingly to the the correct airfuel ratios with out issues making sure there is nothing i am missing?
Re: 07 Honda fit E85 tuning compatibility
You could adjust the overall fuel trim based on the measured ethanol content. Basically every 1% ethanol needs 0.45% more fuel.
