Confirming ethanol and pump gas mixture
ayau
Post by ayau »
I plan to run the Hondata E25 cal on a completely stock 2020 FK8. I’ll be doing my own 93 and E85 mixture to hit E25.
Since I won’t have an ethanol content sensor in the fuel line, is there anything in the datalog I can review to gain comfort that I hit the proper E25 target?
Should I look at AF command and fuel trims? Obviously review for any major knock retards and fuel pump duty cycle as well.
Re: Confirming ethanol and pump gas mixture
For this you really should use an ethanol content sensor.
ayau
Post by ayau »
Spunkster wrote: Wed Jul 01, 2020 10:15 am For this you really should use an ethanol content sensor.
I would be mixing it in fuel containers and then measuring the ethanol content prior to pouring it into the car’s fuel tank.
