Aim MXS 1.2 Strada Dash
jgadell
Post by jgadell »
The install is extremely simple yet my AIM MXS gets 0 readings, is there a way I can test that my green 232TX wire from the S300 is outputting data?
Re: Aim MXS 1.2 Strada Dash
Have you tried swapping RX and TX?
Are you sure the MXL and MXS use the same protocol?
jgadell
Post by jgadell »
I have not tried swapping the RX/TX in fear to maybe fry something. I can try the TX out of the S300 to the Aim's TX and see if maybe they messed up and vice versa. Apparently, they share the same protocol. I've seen some folks running the Strada dashes on Kpro's and S300's
jgadell
Post by jgadell »
Works, connected TX to TX versus TX to RX
DaX
Post by DaX »
Good to know. I've been eyeing the MXS 1.2 Strada.
TX and RX are always named from the viewpoint of the device. eg the S300 TX is the serial transmit from the S300. The MXS TX is the serial transmit from the AiM, so you need to connect TX to RX not TX to TX.
