Horsepower and torque gauges
Janz3n
Post by Janz3n »
Hi, i just recently got the new hondata mobile app and was playing around with it and noticed it had a real time hp and tq reading. how accurate is this?? how is it calculated. i have a 2015 si with intake and exhaust and it reads about 214hp and 200tq peak and find these reading to be rather high.
baltz2012si
Re: Horsepower and torque gauges
Post by baltz2012si »
I have the same app. I have a 2012 civic si and it says hp200 and 186tq. All stock and I did a Hondata reflash
Janz3n
Post by Janz3n »
thanks for the reply. seems as though my assumption of it reading too high is right. still like to know how hondata is calculating these numbers.
It uses airflow to calculate torque, and then hp from torque.
Janz3n
Post by Janz3n »
Hondata wrote: Wed Jun 17, 2020 7:58 pm It uses airflow to calculate torque, and then hp from torque.
any idea of how accurate it is?
Probably ok for comparative changes, but it is not going to replace a dyno.
Kodiesilver1190
Post by Kodiesilver1190 »
I have 2019 Honda type r. I just tuned the car with flashpro with 93oct, Prl exhaust, Prl HVI “race” intake. The hondata app is showing that I’m hitting 361 horsepower. Could this be accurate or am I pushing a little less than that?
I saw that that the app is measuring the air to provide toque numbers and torque numbers give the horsepower.
Just what to have an idea how off or accurate it is.
Thank you
This will not replace an actual dyno and will allow you to compare the numbers with each other but will not be accurate.
Dc5azul
Post by Dc5azul »
My hp guage does not read on my k pro for my 05-06 rsx v4
The K-Pro does not measure air flow and cannot estimate HP.
