TPS not reading any values...
Posted: Sat Jun 06, 2020 5:35 am
Hi guys,
I have recently boosted my b18c4 stock block. I am running a Hondata s300 v1 and when I turn the car on, it will idle fine... the issue lies with the TPS. It’s not reading any values when data logging on the sensors section? I have tried 2 TPS on my car, my old one that I know worked and a brand new one. I have also tried plugging the ecu into my mates ej9 with a b18c4 to see if it read anything and it didn’t.
As mentioned above, the car will idle fine, but because it’s not reading the TPS at all, when I try to rev it even a little it’ll just try to die because the car doesn’t know I’m opening the throttle to let more air in.
After trying it in a friends car and it doing the same issue no reading, it makes me think it has to be something to do with the ecu. What I could really do with finding out is if it is likely to be the p28 board or the actual s300 socket?
With all this aswell, if I try to read the maximum and minimum throttle positions it’ll come up with -5% closed and 60% Wide open. These figures will come up the same where eever the throttle actually is.
I have also tried 3 different adapter harnesses to cancel that out.
I have seen a few other threads on other forums from years ago with the same issue but they never got resolved.
Any help at all would be great, if it’s just a faulty p28 then I’ll be pretty buzzing but I’m just praying it’s not the Hondata.
Full engine spec just incase.
Stock B18c4 with Skunk2 Intake
68mm TB with a new genuine TPS.
AEM Fuel Pressure Reg and Walbro 255 Pump
Evo 560cc Injectors
Speed Factory Racing 4 Bar Map sensor
Evo 560cc Injectors
