Code 41: Oxygen Sensor Heater
ecronic
Post by ecronic »
S300 Serial Number: 42771
SManager Version Number: 2.7.5.0
Calibration: Attached
Datalog: Unavailable
Vehicle: 1996 Honda Civic Del Sol VTEC, B16A6
ECU: P28
Modifications: Top Fuel Air Intake, Skunk2 Gen1 Intake, 4-2-1 PLM Headers, Tanabe Medallion exhaust.
Problem: My calibration has the O2 heater disabled but I still got the O2 heater error. The AEM UEGO gauge displays the AFR running rich and the AFR value on the S300 manager laptop isn't working. This calibration has worked perfectly and just a week ago it started giving error code 41. I've tried clearing the ECU and re-uploaded the map, disconnected ECU from the harness and reconnected.
Thank you for your input.
Thanks & Regards
Ecronic
Re: Code 41: Oxygen Sensor Heater
Please post a datalog using the calibration you have uploaded that shows when the error comes on.
ecronic
Post by ecronic »
Spunkster wrote: Mon Jun 01, 2020 12:54 pm Please post a datalog using the calibration you have uploaded that shows when the error comes on.
Hi Spunkster - sorry for the delay, car was in garage. Please have a look at the datalog attached.
Thanks & Regards
Ecronic
How are you uploading changes to the ECU?
ecronic
Post by ecronic »
I do the changes, save the map and keep the key in the ignition position and click on the upload arrow.
Thanks & Regards
Ecronic
Is it taking all other changes you upload? For example if you set the rev limit to an artificially low 4300 RPM?
ecronic
Post by ecronic »
I haven't done such a test. But you think the s300 is accepting only some changes and not all?
Thanks & Regards
Ecronic
Please try this. There is no way it can take some changes and not others.
ecronic
Post by ecronic »
Okay, will do so and revert back.
Thanks & Regards
Ecronic
ecronic
Post by ecronic »
Spunkster wrote: Mon Jul 27, 2020 4:11 pm Please try this. There is no way it can take some changes and not others.
Hi, got a radiator pipe busted because of which the car is in the garage. I wanted to check with you, I use the x64 version for the sManager whenever I upload the map. Do you think that could be the reason for the s300 to not accept some changes? I've used it for the entire time of the tune and it worked perfectly. Except only when the time I made this post it had started giving this error.
Thanks for your time.
Thanks & Regards
Ecronic
This should not have anything to do with this.
