We have +6 PSI basemap high octane calibration. I understand there is no lower octane calibration for the +6 PSI as the additional boost is higher than stock.
In contrast, +3 PSI calibration has no high octane option.
Could we have +3 PSI calibration in the next update of the firmware?
2016 Civic 1.5T Non-SI +3 PSI high octane
Re: 2016 Civic 1.5T Non-SI +3 PSI high octane
If you use higher octane fuel on the +3 psi the ECU will adjust the knock control down automatically.
Thank you for the explanation.Hondata wrote: Sun May 31, 2020 7:30 am If you use higher octane fuel on the +3 psi the ECU will adjust the knock control down automatically.
