VTC not working on KPro4
jackyft
Post by jackyft »
Hi there,
I was trying use KPro 4 on a K20A Engine Swap. As the VTC was not work well.
Finally I found that Kpro 4 is not support 02-04 anymore. May I know it's depends on ECU or engine? Can I try a newer ECU or I need a newer Engine?
If it cannot support for new KPro4, will hondata have some old version that I can purchase?
Thanks for your support.
Jacky
Re: VTC not working on KPro4
jackyft
Post by jackyft »
Hi there,
The serial number is 53340.
Thx
Jacky
What ECU is the K-Pro installed into?
jackyft
Post by jackyft »
I installed on a PNF-A12
Is ECU related? If so, can u advise which model will work on it?
Thx.
I would recommend that you try this ECU on a known working vehicle and see if VTC works properly.
jackyft
Post by jackyft »
Thanks for your information. May I know can I have your email to discuss the problem? thx.
