Datalog VTS Off
Ice71
Datalog VTS Off
Post by Ice71 »
Hi
I downloaded first calibration to test the car. I took from Flashpro base calibration FK2 Europe with factory settings and I saw VTS always off in first datalog.
Is it a channel address problem or a real VTEC issue? The car seems ok driving it and no DTC
Thanks for your patience
Re: Datalog VTS Off
What version of the software did you upload with? Did you upload Factory settings or Return to Stock?
Ice71
Re: Datalog VTS Off
Post by Ice71 »
I used version 3.5.8 and I uploaded factory settings calibration, NOT return to stock
Car seems ok. I suppose if VTEC is really always OFF I'd feel the car not pushing at high revs.
Re: Datalog VTS Off
I'll check it is datalogging the VTS correctly.
Be aware that VTEC does not work like other vehicles on the FK2 & FK8. VTEC will switch on at idle and cruise sometimes, then generally on for spool, then off and perhaps on at high rpm.
