3.5.8 problem uploading tune to ecu
umddaugh
Post by umddaugh »
Just installed flex fuel and went to upload 93 flex fuel tune, goes through the process, says turn car off, doesn’t clear warning lights and can’t change drive mode. Tried about 10 times and even tried other tune, same result. Called for technical help just get a recorded message.
Re: 3.5.8 problem uploading tune to ecu
If you datalog are there any errors?
umddaugh
Post by umddaugh »
I haven’t data logged
umddaugh
Post by umddaugh »
I uninstalled flash pro manager from laptop & reinstalled hoping this would fix it, same result. Tried uploading a different tune, same result. Dash warning lights stay on and can’t change out of sport mode. Something in the upload process isn’t completing even though it shows it is done and says shut off car. When I do that and try to close flashpro the upload arrow is still highlighted like it hasn’t been uploaded and it asks if I want to save changes........also after I close the turn off car prompt the cursor spins like it is still processing.........
umddaugh
Post by umddaugh »
I emailed a datalog file, I can’t see anything on my end just the info
umddaugh
Post by umddaugh »
Problem solved- had to drive it and all warning lights disappeared and now starts in R mode. Thanks to support
Thanks for the reply and glad it is fixed.
