Page 1 of 3
What is the best calibration map for my mods?
Posted: Mon May 11, 2020 11:38 pm
by CW20038CTR
I only have a V2 version EVENTURI intake, and REMUS catback exhaust soon to be adding front pipe.
What is the best calibration for me?
California 91 oct? I am in los angeles
Also do i leave 10% ethanol for the fuel?
Lastly, do i need a laptop? or can i just type in my VIN to lock this flashpro to my car, and buy the jailbreak with my vin and download the calibrations after?
Sorry i bought this used and the online instructions are a little unclear for me.
Re: What is the best calibration map for my mods?
Posted: Tue May 12, 2020 10:47 am
You will need a laptop to do the instant jailbreak and to be able to upload to the ECU.
What is different on this new intake?
If it has been properly unlocked by the previous owner then using it on your vehicle is no different than purchasing a new one. If they did not unlock it, then you may want to get your money back form the seller.
Posted: Tue May 12, 2020 3:24 pm
by CW20038CTR
its unlocked.
Do you know which calibration i should use?
Should i use just the standard 91 oct, no mods map? and then click eventuri?
Posted: Wed May 13, 2020 7:40 am
Yes, but the mod for eventuri was for the original version, not the v2. The original eventuri changed the AFM flow and needed tuning; we do not know with the v2. You could try it and then look at your fuel trims.
Posted: Wed May 13, 2020 3:20 pm
by CW20038CTR
Do you guys want to do testing on a car with the newer intake to make an updated map?
lol i am local =)
Posted: Wed May 13, 2020 3:21 pm
by CW20038CTR
Hondata wrote: Wed May 13, 2020 7:40 am
lol i am local =)
Posted: Wed May 13, 2020 5:58 pm
Do a datalog and look at your fuel trims.
Posted: Fri May 15, 2020 6:46 pm
by CW20038CTR
Hondata wrote: Wed May 13, 2020 5:58 pm
Sorry if this is a dumb question but does data logging require me to drive around with it plugged in and avtively log while i drive around?
Or can i just plug it in and click data log and be done?
Also im looking at it on idle and Ltrim is -2%
Posted: Sat May 16, 2020 8:55 am
Plug in the FlashPro, start up, press the datalog, drive around for 20 minutes with varied driving, take the FlashPro and download the datalog then post the datalog here.
Posted: Sat May 16, 2020 10:33 am
by CW20038CTR
datalogEventuriV2.fpdl
Here you go
So my selections are below
I am in los angeles california
91 oct
+ eventuri Intake
Rev hang
Stock fuel pump
Remove factory boost limits
Fuel pump gas with 10% ethanol
Improved throttle with full power 1st and 2nd
Traction control aggressive launch
Increase turbo charger boost limit
Increase turbo charge pressure ratio
Please let me know if i have any issues or if i need to do anything. I hope it all looks good
Is there anythign i have to look at carefully? or what values and what they should be to monitor
Posted: Mon May 18, 2020 9:18 am
by CW20038CTR
Hondata wrote: Sat May 16, 2020 8:55 am
You get a chance to look at it?
Posted: Mon May 18, 2020 9:46 am
Posted: Mon May 18, 2020 10:38 am
by CW20038CTR
Hondata wrote: Mon May 18, 2020 9:46 am
Seems fine
thank you.
that gives me peace of mind
Posted: Fri May 22, 2020 7:28 pm
by CW20038CTR
So with all the settings above.... im noticing something strange with 1st and 2nd
It seems to bog at like 6500 like if that is the new redline... any idea?
Posted: Sat May 23, 2020 8:28 am
Probably the VSA closing the throttle. A datalog would help.
